Does anyone know how to convert an ascii string to the real value? I am taking a hex buffer (42,14,8F,5C) and converting to its ascii equivalent using oscat_basic.BUFFER_TO_STRING. I am now stuck on how to convert this value in its real value (37.140) to display on HMI. Thanks.
If you are starting with IEE754 (a codesys REAL type) then you could use "SomeString := TO_STRING(UrRealVal);" Probably it would be better to put "UrRealVal" into a TextVariable field and a format (i.i. %2.3f) in the Text field of a viosualization element.
that's the bit pattern for an iee754 floating point number, not a string.
And it's 3.714 not 37.14
a hint how formatted "printing" of reals in strings is possible:
https://forge.codesys.com/forge/talk/Engineering/thread/f05178ced3/?limit=25#904a
