raspistepper error after install
2024-04-20
2024-09-30
  • installwhat - 2024-04-20
    I've had issues getting the raspistepper installed, all due to errors upon installation.
    The closest I get is the pictured error. The functions are in the sm3_shared library. I can add this library but that leaves 2 issues.
    I don't actually know, and I really want to understand this, why the required dependencies haven't been installed correctly.
    If I add the library it's only available with through the namespace.
    What can I do to both understand and resolve this?
    edit
    codesys 64 3.5.20.0 - same error on other versions too
    sm3 raspi stepper 0.0.0.5
    Last edit: installwhat 2024-04-20
    I'm digging into it and see that sm3_shared is nested in the library manager raspistepper->sm3_drive_poscontrol->sm3_shared
    but I get errors
    from another post on this forum
    In your library project select Project -> Project Information. On the Properties table remove the "LanguageModelAttribute" Value "Qualified Access Only".
    This will allow you to access the object without qualifying the access.
    I guess they've compiled it the library with that setting and now I need to mess around with versions.
  • installwhat - 2024-04-21
    to fix this I used a sp17 codesys and changed the project setting softmotion version to 4.6.2.0.
    I'm not sure if I should have had such difficulties but it works now.
  • dangjoris - 2024-09-30
    Hi, I am in the same situation. Is this still your best method? To go back to sp17?
    best regards
    Ok with the new Release of SM3RaspiStepper 0.0.0.6 it is fixed. Everything works fine with CODESYS Control for Raspberry Pi SL 4.13.0.0 and CODESYS SDK 3.5.20.20
