It is a Lenze i700 servo drive, built some code taking the cyclic rate and cyclic rate of the machine into consideration and got it working with a software window in normal logic that uses normal tp trigger block without window active.
The window mode seems to not be supported on this inverter.
Thank you for the answer.
for the life of me i can't get the MC_Touchprobe to work in a window mode.
Without window it works 100% as expected with the internal tp of the drive.
As soon as we execute the MC_Touchprobe with the WindowOnly true it tells me SMC_TP_COULDNT_SET_WINDOW.
Does anyone know what is required to set this window. I am assuming it needs to be a modulo axis to TP to work.
Kind Regards
Shaun
which drive is this?
You need to check the documentation inside the motion library if this is supported on your device.
Hi Edwin
