Modbus TCP error > Slave does not support this register offset
2020-08-31
2020-09-05
  • manueldiasm - 2020-08-31
    I am trying to communicate by Modbus TCP being Codesys the master to a Micro 820 from Rockwell automation but i get the error " Slave does not support this register offset ". Any help to solve this issue ?
    Regards,
    MDias
  • i-campbell
    i-campbell - 2020-08-31
    What does your Modbus Mapping look like in CCW?
    What does your Modbus channel configuration look like in CODESYS?
  • manueldiasm - 2020-09-01
    The Modbus Tool that communicates fine with CCW does not communicate with Codesys as a Master . Any tip ?
    When i use the same tool being Codesys the slave the communication is fine. Help ?
  • kislov - 2020-09-02
    As I see in CODESYS you use Modbus function 03 but in Modbus tool you use function 01 (because variable type: coils). I think you should try function 01 in CODESYS too.
  • manueldiasm - 2020-09-02
    Thanks, but i have already tried all type of Modbus Function with Codesys and even i tried to use a PLC from Siemens insetad of Micro820 but no success so far.
    Codesys as a slave seems to work fine but not as a master. 😟
    I am using a Pi 3+.
    • aliazzz
      aliazzz - 2020-09-02
      Why don't you try to read/write into your localhost pi using the CODESYS master first? That way you can test it without external tools and get a better feeling for it.
  • manueldiasm - 2020-09-05
    ItΒ΄s working well with CCW now. Thank you for your wise advice.
