I plan to use BeagleBone Black (BBB) board with Codesys cores to perform tasks like PLC + HMI devices. Graphical are output via HDMI. What's Codesys license I need to buy so that BBB can perform PLC tasks and display HMI interface at the same time.
Tks
Sorry, I may have described the project unclear. If I want to use BBB as PLC, I must get CODESYS Control for BBB SL. And If I want to use BBB as HMI (exp: to connect Siemens PLC), I must get CODESYS TargetVisu SL. So, if I want to use BBB as All in one PLC + HMI, do I need all these licenses? Webvisu may be good but I'd like to use HMI app.
Tks
Target Visu not possible to have with this BBB SL release from the store.
So the only way to do it -> use webvisu in fullscreen kiosk mode in the browser.
On Raspberry PI this look using webvisu and browser in fullscreen mode feel similar to targetvisu.
On BBB you need to check if it is performant enough for your needs.
π
1
Tks
more posts ...
See;
https://store.codesys.com/codesys-control-for-beaglebone-sl.html?___SID=U
and to store the license securely buy this too;
https://store.codesys.com/codesys-key.html
(just activate the lic on the key and stick the key into the BB)
Tks for your reply
I mean I want to run codesys visualization on the same board without web browser. Do I need additional CODESYS TargetVisu SL?
No this does not work, you might execute the webvisu in kiosk mode of the browser
Last edit: eschwellinger 2020-05-29
Tks
To be honest I never used HMI SL as Webvisu works very well for my type of projects. Maybe you try out a DEMO for it?
