Google Maps Application in Webvisu - warning
adisz
2018-08-14
2019-01-24
  • adisz - 2018-08-14
    I'm trying to run example of "Google Maps Application in Webvisu" from this link: l viewtopic.php?p=16175#p16175 l
    After downloading I'm getting 2 warnings about missing control "3S.NativeControl.GoogleMaps". Is it somewhere avaiable to get and how could I add it to codesys?
    Thanks.
  • CanBohr - 2018-12-06
    Hi adisz,
    have you solved the problem and have you got googlemaps to work on codesys?
    Cheers,
    CanBohr
  • adisz - 2019-01-23
    Unfortunatelly no, and you?
    eschwellinger - 2019-01-24
    I would recommend to check the following:
    1. API KEY added in googlemaps_ext1.js in line 395 TODOSETKEY API KEY
    How to get the these API KEY?
    https://developers.google.com/maps/docu ... et-api-key
    2. rename webvisu2.cfg.json to webvisu.cfg.json in /var/opt/codesys/PlcLogic/Application/webvisu.cfg.json
    to check all this use F12 in your Firefox Browser so see the JavaScript error Messages - when you execute the Webpage
    3. As Always check plc logger for Errors
    IMG: webvisu.cfg.json_rename.png
