Struggeling with Task time
Lostin
2018-12-28
2018-12-30
  • Lostin - 2018-12-28
    Hi, i'am a still reader until now and many things where really helpfull in this forum.
    So thank you all
    Now i'am getting to a point i can't figure out for my own, maybe someone can help me and give me some advice.
    A have a few tasks and all splittet up with different priorities and times, in this case i have a sytemtime task that needs up to 18s to finish, what is really to slow and i don't understand why it needs so long, actually this is the taks with the priority 1 but even that needs 18s.
    Can someone explain me what i'am doing wrong?
    Greetings Silvio
    IMG: Systemzeit.jpg
    IMG: Systemzeit Programm.jpg
  • Ingo
    Ingo - 2018-12-28
    Hi Silvio,
    purely from the screenshots I couldn't find anything suspicious. But because the minimal and maximal cycle time are differing so much, I expect, that you are calling a function, which simply blocks from time to time.
    Maybe you can just copy&paste the code of the whole PRG!?
    BR,
    Ingo
    Hi Ingo,
    Thanks for your fast reply, i guess it gets a little bit difficult to post all the code.
    It is poosible to attache the whole programm?
    so you think i use a code or variable that avoid the systemtime cycle to run complete free
    BR Silvio
  • Ingo
    Ingo - 2018-12-28
    Yeah, you can also attach the whole project as an attachment. But I thought, that the code of the systemtetime PRG might be enough.
  • Lostin - 2018-12-29
    Good Morning,
    i'am trying to attache the whole project, the code you see in the picture is the whole code there are no more lines.
    I make an archive with codesys that are including all libarys and things i use.
    Thanks for your passion and help
    https://drive.google.com/file/d/1h0WRDV ... sp=sharing m
    eschwellinger - 2018-12-30
    without gooing deeper in your code, I think the problem are these 3 onewire devices which I think you have missed to specify the correct update task.
    IMG: onewire.png
  • Lostin - 2018-12-30
    Good Morning
    you are so right, this was really the problem.
    Thanks allot, i add these sensors a litte bit later and really forget to declare which task they are in...OMG.
    Silvio
