webVisu red X
2020-04-24
2020-04-28
  • jeffersonhui - 2020-04-24
    In webVisu, why do some of my images show up as a Red "X"? I tried changing the image between jpg and png formats, but this did not solve the issue.
    I attached screenshots of what the web visualization looks like, and what it is supposed to look like.
    Thanks,
    Jefferson
  • m.prestel - 2020-04-27
    Hello @jeffersonhui,
    the red crosses indicate that the image was not loaded.
    Try to do a complete download of the application.
    Best regards,
    Marcel
  • jeffersonhui - 2020-04-27
    Hi, Marcel,
    I just performed a "Reset Origin," and then downloaded the application again, but got the same results unfortunately. Is there anything else I should try?
    Thanks,
    Jefferson
    eschwellinger - 2020-04-28
    You could check with the CODESYS file browser if these visu files are in /PlcLogic/Visu directory - and check the plclogger..
    Last edit: eschwellinger 2020-04-28
  • jeffersonhui - 2020-04-28
    Hi, Edwin,
    i just checked and the file IS in the /opt/CoDeSysControl/visu/ folder.
    What is the plclogger?
    Thanks,
    Jefferson
    here:
    Hi, Edwin,
    I just solved the issue. It turns out that the image name had 2 spaces in a row in it, and when I removed one of the spaces and downloaded again, the web visualization worked!
    Thanks,
    Jefferson
