Information and guides
This page
Introduction | Installation
This is a recipe to setup a free test system for use with Sparkplug for CODESYS with an Ignition Primary Host.
If you follow this recipe closely it "should" take you between 1 or 2 hours, depending on your experience.
Need any help? -> Drop us a question below, we are happy to assist you.
It's up to you to decide which flavor of Ignition you wish to run as they are identical but differ in use-case scenario.
The provided information is not intended as advertisement but merely to provide you with enough information for you to make a choice on what installation is best suited for you.
Ignition Maker Edition has powerful industrial-grade features of Ignition Enterprise by Inductive Automation️® to any number of your personal or educational projects
at no cost. All you need is a permanent internet connection for it to work (so called 'always connected'). This seems for most purposes the optimal choice.
https://inductiveautomation.com/ignition/maker-edition for more information
This is the full fledged version of Ignition Enterprise SCADA. Without proper licensing it runs in a DEMO trial period for 2 hours.
The trialperiod can be extended an unlimited amount of times by a single push of a button.
https://inductiveautomation.com/ignition/ for more information
Host software
Client Software
This guide assumes you have Windows 10 and WinSCP already installed on a PC. Feel free to deviate in any way from this guide.
* Download the latest version of all the components listed above:
* With the CODESYS Development System V3 installer, CODESYS Control Win 64 and CODESYS Gateway 64 are also installed.
* Once CODESYS Development System is installed, double click the IIoT Libraries SL package to install it. This has a 30 minute demo, which is reset when you restart the PLC.
* Install mqtt.fx. This is an MQTT client, which also has a SparkplugB decoder. Handy for debugging.
Use scp from a windows command prompt to copy the installer to your linux box
You did it!
Need help? -> Drop us a question, we are happy to assist you.
Home: Add SparkplugB to existing CODESYS project
Home: General Sparkplug info
Home: Home
Home: Infrastructure
Home: Messages
Home: Preview how-to
Home: Security
