An input on the Device POU should trigger sending a DDEATH certificate for this device.
This input serves to accommodate this as the customer can then build a watchdog in their application to monitor the physical device. If the physical device is offline and the watchdogs triggers, this will be notified to the primary SCADA.
FB_Device input : Device_Healthy, must be TRUE, if this signal becomes FALSE the DDEATH certificate will be issue if the connectionstate is online. During this phase the device will not send any data again. After the Device_Healthy has been set to TRUE, the device can resume it's normal course of functioning again (plugged, DBIRTH, DDATA etc).
This mechanisms requires at least two states: DDEATH and HEALTH_RESTORE state
DDEATH publishes the DDEATH certificate and after this the device moves to HEALTH_RESTORE state where the device idles and waits until the device health status returns to normal. After this the Device returns to the INIT state and resumes PLUGGED/ONLINE
Note that the monitoring and sending of the input is only valid during device online sessionstate. If the EON session turns to offline during DDEATH period, the device will stay in HEALTH_RESTORE until the device is again healthy. If so the device goes to INIT and resumes plugged/ OFFLINE
Diff:
Done in V1.3.0.2
