There is a non-normative compression practice in the Tahu project.
https://github.com/eclipse/tahu/blob/develop/client_libraries/java/src/main/java/org/eclipse/tahu/util/PayloadUtil.java
Essentially, you
1. compress the payload to an array of bytes using GZIP or DEFLATE.
2. This array of bytes is put in the payload.body.
3. Optionally, a single payload.metrics named "algorithm", of datatype String contains the string_value either "GZIP" or "DEFLATE". If this is not included, then "DEFLATE" will be assumed.
4. paylaod.uuid contains the text "SPBV1.0_COMPRESSED"
eg.
{"timestamp": 16000000000, "metrics": [{"name": "algorithm", "timestamp": 16000000000, "datatype": "String", "string_value": "GZIP"}], "seq": 12, "uuid": "SPBV1.0_COMPRESSED", "body": <GZIP compressed bytes of the actual payload> }
or
{"timestamp": 16000000000, "seq": 12, "uuid": "SPBV1.0_COMPRESSED", "body": <DEFLATE compressed bytes of the actual payload> }
plusses are myriad like optimised CPU usage, so hardly any loss of performance.
minus: CPU must support it and needs a special dedicated library which enables it.
