Proof and Update the following to match latest library:
[x] Add to existing
[x] Set up Test Server - rename to setup a test system with Ignition Primary Host
Add the following guides:
[x] setting up a test environment with a co⚡e primary host
--- old+++ new@@ -3,4 +3,4 @@
[ ] [Set up Test Server](https://forge.codesys.com/prj/mqttsparkplugb/home/Set%20up%20test%20system/) - rename to setup a test system with Ignition Primary Host
-[ ] setting up a test environment with a co⚡e primary host+[X] setting up a test environment with a co⚡e primary host
--- old+++ new@@ -3,4 +3,4 @@[ ] [Set up Test Server](https://forge.codesys.com/prj/mqttsparkplugb/home/Set%20up%20test%20system/) - rename to setup a test system with Ignition Primary Host
-[X] setting up a test environment with a co⚡e primary host+[x] setting up a test environment with a co⚡e primary host
--- old+++ new@@ -1,6 +1,6 @@
-[ ] [Add to existing](https://forge.codesys.com/prj/mqttsparkplugb/home/Add%20SparkplugB%20to%20existing%20CODESYS%20project/)-[ ] [Set up Test Server](https://forge.codesys.com/prj/mqttsparkplugb/home/Set%20up%20test%20system/) - rename to setup a test system with Ignition Primary Host+* [ ] [Add to existing](https://forge.codesys.com/prj/mqttsparkplugb/home/Add%20SparkplugB%20to%20existing%20CODESYS%20project/)+* [ ] [Set up Test Server](https://forge.codesys.com/prj/mqttsparkplugb/home/Set%20up%20test%20system/) - rename to setup a test system with Ignition Primary Host
-[x] setting up a test environment with a co⚡e primary host+* [x] setting up a test environment with a co⚡e primary host
-* [ ] [Add to existing](https://forge.codesys.com/prj/mqttsparkplugb/home/Add%20SparkplugB%20to%20existing%20CODESYS%20project/)-* [ ] [Set up Test Server](https://forge.codesys.com/prj/mqttsparkplugb/home/Set%20up%20test%20system/) - rename to setup a test system with Ignition Primary Host+[ ] [Add to existing](https://forge.codesys.com/prj/mqttsparkplugb/home/Add%20SparkplugB%20to%20existing%20CODESYS%20project/)+[ ] [Set up Test Server](https://forge.codesys.com/prj/mqttsparkplugb/home/Set%20up%20test%20system/) - rename to setup a test system with Ignition Primary Host
-* [x] setting up a test environment with a co⚡e primary host+[x] setting up a test environment with a co⚡e primary host
--- old+++ new@@ -1,6 +1,6 @@Proof and Update the following to match latest library:
-[ ] [Add to existing](https://forge.codesys.com/prj/mqttsparkplugb/home/Add%20SparkplugB%20to%20existing%20CODESYS%20project/)-[ ] [Set up Test Server](https://forge.codesys.com/prj/mqttsparkplugb/home/Set%20up%20test%20system/) - rename to setup a test system with Ignition Primary Host+[x] [Add to existing](https://forge.codesys.com/prj/mqttsparkplugb/home/Add%20SparkplugB%20to%20existing%20CODESYS%20project/)+[x] [Set up Test Server](https://forge.codesys.com/prj/mqttsparkplugb/home/Set%20up%20test%20system/) - rename to setup a test system with Ignition Primary HostAdd the following guides:
Diff:
Diff:
Diff:
Diff:
Diff:
Reopen if not satisfactory
