#156 Tutorials: go over and check for correctness
2.0.0.0: Example
open
nobody
2022-02-09
2022-02-09
No
The tutorials are out of date. For example, some refer to installing the "SparkplugB" library, but this is now the three libraries starting with co⚡e. The tutorials should be give a run through, and corrected for current usage.
Check the following:
Preview How To <<< Needs updating
Setup a test system with Ignition Primary Host <<< needs some updating
Add SparkplugB to an existing CODESYS project <<< needs updating
Discussion
  • hermsen
    hermsen - 2022-02-09
    • Description has changed:
    Diff:
    --- old
    +++ new
    @@ -1,6 +1,8 @@
     The tutorials are out of date.  For example, some refer to installing the &#34;SparkplugB&#34; library, but this is now the three libraries starting with co⚡e.  The tutorials should be give a run through, and corrected for current usage.
    -Preview how-to
    -Setup a test system with Ignition Primary Host
    -Add SparkplugB to an existing CODESYS project
    +Preview how-to &lt;&lt;&lt; Can be deleted
    +Setup a test system with Ignition Primary Host &lt;&lt;&lt; needs some updating
    +Add SparkplugB to an existing CODESYS project &lt;&lt;&lt; needs updating
  • hermsen
    Diff:
    --- old
    +++ new
    @@ -1,7 +1,7 @@
    -Preview how-to &lt;&lt;&lt; Can be deleted
    +Preview How To &lt;&lt;&lt; Needs updating
Log in to post a comment.
