#160 FB_Edge: Move Connect to VAR_INPUT, and rename to Enable, and Implement
2.0.0.0: Edge
closed
2022-07-17
2022-07-01
No
FB_Edge has a local variable Connect.
  1. Move it to VAR_INPUT
  2. rename Connect to Enable
  3. document its behaviour
  4. Implement the functionality
    a. [x] Edge shall not start until enabled.
    b. [#165] Edge shall disconnect and a NDEATH will be published.
*Implementation of NDEATH has been splitted of and moved to [#165]
Related
Progress Blog: 2022/07/2-july-2022-updated-tck-test-results
Tickets: #161
Tickets: #165
Discussion
  • hermsen
    hermsen - 2022-07-02
    • status: open --> accepted
  • hermsen
    hermsen - 2022-07-17
    • Description has changed:
    Diff:
    --- old
    +++ new
    @@ -1,9 +1,10 @@
    -1. Move it to VAR_INPUT
    -2. rename Connect to Enable
    -3. document its behaviour
    -4. Implement the functionality
    +1. [x] Move it to VAR_INPUT
    +2. [x] rename Connect to Enable
    +3. [x] document its behaviour
    +4. Implement the functionality
    +    a. [x] Edge shall not start until enabled.
    +    b. [#165] Edge shall disconnect and a NDEATH will be published.
    -     a. Edge shall not start until enabled.
    -     b. Edge shall disconnect and a NDEATH will be published.
    +*Implementation of NDEATH has been splitted of and moved to [#165]
    Related
    Tickets: #165
  • hermsen
    Diff:
    --- old
    +++ new
    @@ -3,7 +3,8 @@
    Related
    Tickets: #165
  • hermsen
    This ticket took quite some effort to program.
    It yielded a new FB_ExponentialBackOffTimer and accompanying unittest.
    The rework has also fixed [#161] incorrect connection status.
    Related
    Tickets: #161
  • hermsen
    • labels: Improvement -->
    • status: accepted --> closed
Log in to post a comment.
