- labels: --> TCK
If you run the example project against the current develop branch of the Sparkplug TCK https://github.com/eclipse/sparkplug/ , you get the following failing test:
message-flow-edge-node-birth-publish-connect: FAIL Any Edge Node in the MQTT infrastructure MUST establish an MQTT Session prior to publishing NBIRTH and DBIRTH messages.;
Progress Blog: 2022/07/2-july-2022-updated-tck-test-results
Tickets: #84
Log in to post a comment.
