#69 MQTT: ping interval should = keep alive time
1.0.0.0: EoN
closed
2020-10-15
2020-10-09
No
The MQTT spec says "If the Keep Alive value is non-zero and the Server does not receive a Control Packet from the Client within one and a half times the Keep Alive time period, it MUST disconnect the Network Connection to the Client as if the network had failed"
IS: currently in our library Ping interval is fixed at 15s, but KeepAlive is set by the user. In the example it is set to 60 seconds.
SHUOLD: The ping interval should be set equal to the KeepAlive time
Discussion
  • i-campbell
    i-campbell - 2020-10-09
    • Owner: aliazzz --> h-hermsen
    • Milestone: 9.9.9.9: Backlog --> 1.0.0.0: EoN
  • hermsen
    hermsen - 2020-10-13
    • status: open --> closed
  • hermsen
    In trunk with 0.9.0.4
  • i-campbell
    i-campbell - 2020-10-13
    • status: closed --> open
    • assigned_to: h-hermsen --> i-campbell
  • i-campbell
    Reopened, because currently it is set at T#15ms, for a keep alive of 15 (seconds).
    This is one thousand times smaller than it should be.
  • hermsen
    Just slap 1000* in between the TO_TIME conversion, problem solved.
  • hermsen
    hermsen - 2020-10-15
Log in to post a comment.
