#82 EoN: SparkplugSimple.Notify requires handshake
1.0.0.0: EoN
closed
2020-10-24
2020-10-22
No
At the moment, if a SparkplugSimple.Value is written with a new value, a notify bit is set. If it is written again without changing the value, the notify bit is cleared.
This should be changed to:
if a SparkplugSimple.Value is written with a new value, a notify bit is set. If the notification is acknowledged, the notify bit is cleared.
The code which uses the notification should then call the AcknowledgeNotify() method.
Discussion
  • hermsen
    hermsen - 2020-10-22
    • status: open --> pending
  • hermsen
    Fixed in v0.9.9.0
  • hermsen
    hermsen - 2020-10-24
    • labels: EoN, Bug -->
    • status: pending --> closed
Log in to post a comment.
