#94 (Bd)SeqNum flow control issue's
closed
2020-12-12
2020-11-21
No
The EoN sends NDATA payloads.
The Device is allowed to send DDATA payloads (by/through command of the EoN)
It seems that the DDATA payloads are tagged with a SeqNum that is too high (it needs to be N, but is tagged with N+1)
This incorrect tagging (N+1) causes/triggers the Server Node to issue a DBIRTH NCMD.
Improve "assigning of seqnums to payloads" by implementing a mechanism to tag payloads "just in time" with a correct seqnum. This ticket also has a certain relation with "Improve control of/over/with statemachine [#93]"
Related
Tickets: #93
Discussion
  • hermsen
    hermsen - 2020-11-21
    Incorrect SeqNum tagging is solved in V1.1.0.10 in my branch.
  • hermsen
    hermsen - 2020-11-23
    V1.10.0.11 has resolved the issue completely.
  • hermsen
    hermsen - 2020-11-26
    • status: accepted --> pending
  • hermsen
    Fix present in 1.1.0.13 in personal branch => merge into trunk
  • hermsen
    hermsen - 2020-12-12
    • Description has changed:
    Diff:
    --- old
    +++ new
    @@ -2,13 +2,6 @@
    -This incorrect tagging (N+1) causes/triggers the Server Node to issue a DBIRTH NCMD.
    -This results in a Sparkplug EoN Node that is in a continuous cycle;
    +This incorrect tagging (N+1) causes/triggers the Server Node to issue a DBIRTH NCMD.
    -    NBIRTH,
    -    NDATA,
    -    DBIRTH,
    -    DDATA,
    -    NCMD-ReBirth (next step is NBIRTH again)
    Related
    Tickets: #93
  • hermsen
    • status: pending --> closed
Log in to post a comment.
