[[members limit=20]]
[[download_button]]
[TOC]
* 100% Open source,
# Changelog
* v2.0.0.0 info
# IO interface
# i2c slave address setting
Start your Raspberry Pi withe MEGAIO attached.
Run sudo i2cdetect -y 0 => You should now see a table with the connected i2c slave address.
If Run sudo i2cdetect -y 0 does not work, Run sudo i2cdetect -y 1
*The MEGAIO default address is 16#31 (41dec).
# Package
Sorry, work in progress!
# Limitations / Bugs
See [tickets](https://forge.codesys.com/drv/mega-io/tickets/)
