[[members limit=20]]
[[download_button]]
[TOC]
* 100% Open source,
# Changelog
* v2.0.0.0 info
# I2C address setting
# IO interface
# Package
Sorry, work in progress!
# Limitations / Bugs
See [Tickets](https://forge.codesys.com/drv/mega-io/tickets/)
