aliazzz
[[members limit=20]]
[[download_button]]
[[download url=https://forge.codesys.com/drv/mega-io/code/HEAD/tree/tags/v2.0.0.0/package/IoDrvMEGAIO%20v2.0.0.0.package?format=raw]]
[TOC]
This driver is a IoDrvFB based wrapper around the Raspberry I2C MEGAIO driver v1.1.0.0 for CODESYS by [Sequent Microsystems](https://www.sequentmicrosystems.com/index.html).
* This IO driver replaces the FB based program calls with mappable hardware channels,
* 100% Open source,
* 100% Pure IEC 61131-3 code (ST).
Sequent Microsystems uploaded a video about the Mega IO Industrial for Raspberry Pi, check it out :
## IO interface benefits
[[img src=https://forge.codesys.com/drv/mega-io/code/HEAD/tree/screenshots/IoDrvMEGAIO%20Parameters.png?format=raw width=60%]]
[[img src=https://forge.codesys.com/drv/mega-io/code/HEAD/tree/screenshots/IoDrvMEGAIO%20IoMapping.png?format=raw width=60%]]
* Example Project with visualisation
[[img src=https://forge.codesys.com/drv/mega-io/code/HEAD/tree/screenshots/IoDrvMEGAIO%20Application%20Visualisation.png?format=raw width=60%]]
## Changelog
* v2.0.0.0 by Aliazzz under "Unlicense". Released on cForge. See https://forge.codesys.com/drv/io-drivers/database/Home/ for details.
* v1.1.0.0 by [Sequent Microsystems](https://www.sequentmicrosystems.com/index.html) under "Unlicense".
## I2C address setting
##Package installation
![](https://forge.codesys.com/drv/mega-io/code/HEAD/tree/screenshots/IoDrvMEGAIO%20package.png?format=raw )
Install the package via;
* Double-click the package or via CODESYS IDE Package Manager,
* Install the loose components via the Library / Device Repository, found under Tools menu option in CODESYS IDE.
## Limitations / Bugs
If you experience any bugs or limitations, please leave a [Ticket](https://forge.codesys.com/drv/mega-io/tickets/)
## Acknowledgements
Special thanks goes out to Ingo Hornberger for helping out with difficulties and for his patience.
