codesys.com Ingo Falk
How to bind a Rotary Encoder
Hardware
Usage
Example Project
Setup:
Now connect the outputs of the KY040 with the Raspberry Pi like this:
CLK --> GPIO - Pin
DT --> GPIO - Pin
SW --> GPIO - Pin
+ --> 5.0 VDC Power
GND --> 0 V (Ground)
At this point you could install another KY040, in the same way but different pinouts like the first one, if you want to play for example "retro-games".
On the picture below you can see an example of the retro-games project. For example you can insert a "Box" out of your ToolBox which is very easy to program.
