#149 Add Edge Info Properties
closed
2021-12-03
2021-11-20
No
Discussion
  • hermsen
    hermsen - 2021-11-21
    • Description has changed:
    Diff:
    --- old
    +++ new
    @@ -1,8 +1,8 @@
    -We should publish lots of hardware and software info obtained from the platform which the Edge runs on. All the info is aggregated and then published in the metric "About Info" with access "read-only".
    +We should publish lots of hardware and software info obtained from the platform which the Edge runs on. All the info is aggregated and then published in the metric "About Info" with access "read-only
    -https://faq.codesys.com/display/CDSFAQ/Reading+the+Manufacturer+Information+of+the+Controller
    +* [x] https://faq.codesys.com/display/CDSFAQ/Reading+the+Manufacturer+Information+of+the+Controller
    -https://faq.codesys.com/display/CDSFAQ/Reading+the+IP+and+MAC+Addresses+from+AdapterInfo
    +* [ ] https://faq.codesys.com/display/CDSFAQ/Reading+the+IP+and+MAC+Addresses+from+AdapterInfo
     https://faq.codesys.com/display/CDSFAQ/Reading+the+Compiler+and+Runtime+Version
  • hermsen
    Diff:
    --- old
    +++ new
    @@ -1,12 +1,12 @@
    -* [x] https://faq.codesys.com/display/CDSFAQ/Reading+the+Manufacturer+Information+of+the+Controller
    -* [ ] https://faq.codesys.com/display/CDSFAQ/Reading+the+IP+and+MAC+Addresses+from+AdapterInfo
    -https://faq.codesys.com/display/CDSFAQ/Reading+the+Compiler+and+Runtime+Version
    +* [ ] https://faq.codesys.com/display/CDSFAQ/Reading+the+Compiler+and+Runtime+Version
    -https://faq.codesys.com/pages/viewpage.action?pageId=21135402
    +* [ ] https://faq.codesys.com/pages/viewpage.action?pageId=21135402
    -https://faq.codesys.com/display/CDSFAQ/Identifying+the+Hardware+and+Operating+System
    +* [ ]  https://faq.codesys.com/display/CDSFAQ/Identifying+the+Hardware+and+Operating+System
  • hermsen
    hermsen - 2021-11-27
    Diff:
    --- old
    +++ new
    @@ -1,12 +1,12 @@
    +*[x]  https://faq.codesys.com/display/CDSFAQ/Reading+the+Manufacturer+Information+of+the+Controller
    +*[ ]  https://faq.codesys.com/display/CDSFAQ/Reading+the+IP+and+MAC+Addresses+from+AdapterInfo
    -* [ ] https://faq.codesys.com/display/CDSFAQ/Reading+the+Compiler+and+Runtime+Version
    +*[ ] https://faq.codesys.com/display/CDSFAQ/Reading+the+Compiler+and+Runtime+Version
    -* [ ] https://faq.codesys.com/pages/viewpage.action?pageId=21135402
    +*[ ] https://faq.codesys.com/pages/viewpage.action?pageId=21135402
    -* [ ]  https://faq.codesys.com/display/CDSFAQ/Identifying+the+Hardware+and+Operating+System
    +*[ ]  https://faq.codesys.com/display/CDSFAQ/Identifying+the+Hardware+and+Operating+System
    • assigned_to: h-hermsen
  • hermsen
    Diff:
    --- old
    +++ new
    @@ -1,12 +1,8 @@
    -*[x]  https://faq.codesys.com/display/CDSFAQ/Reading+the+Manufacturer+Information+of+the+Controller
    -*[ ]  https://faq.codesys.com/display/CDSFAQ/Reading+the+IP+and+MAC+Addresses+from+AdapterInfo
    -*[ ] https://faq.codesys.com/display/CDSFAQ/Reading+the+Compiler+and+Runtime+Version
    -*[ ] https://faq.codesys.com/pages/viewpage.action?pageId=21135402
    -*[ ]  https://faq.codesys.com/display/CDSFAQ/Identifying+the+Hardware+and+Operating+System
  • hermsen
    hermsen - 2021-12-03
    Diff:
    --- old
    +++ new
    @@ -1,8 +1,11 @@
    +We should publish lots of hardware and software info obtained from the platform which the Edge runs on. All the info is aggregated and then published in the metric "ABOUT" with access "read-only
    +* [x]  https://faq.codesys.com/display/CDSFAQ/Reading+the+IP+and+MAC+Addresses+from+AdapterInfo
    +* [x] https://faq.codesys.com/display/CDSFAQ/Reading+the+Compiler+and+Runtime+Version
    +* [x] https://faq.codesys.com/pages/viewpage.action?pageId=21135402
    +* [x] https://faq.codesys.com/display/CDSFAQ/Identifying+the+Hardware+and+Operating+System
    +added Opt-Out IWantExtendedEdgeInformation : BOOL := TRUE;
    +https://forge.codesys.com/lib/cobolt/cobolt-edge/ci/71221096fbe2cabd8304e28b874874f9c67fe13a/
    • status: open --> closed
Log in to post a comment.
