--- old+++ new@@ -6,3 +6,16 @@
* Application nodes can look only at devices they are interested in (for example a HMI node that only wants data for the page it is on)
Workaround: until this is implemented, all Metrics that would have been put in a device, can be published instead as EoN Node Metrics
++Ideas for implementation:+FB_Device+ - based on FB_EoN+ - every FB_Device has its own Publisher+ - every FB_Device has its own Subscriber+ - every FB_Device has its own AllMetricsList+ - shared connection with the EoN. i.e. there is only one connection++an ARRAY [*] of FB_Device will be passed by the user to FB_EoN++"not enough subscribers" error too, for MQTT.MQTTParam.g_udiMaxPublishersAndSubscribers+This is not yet needed, as we are generally under the default value of 20 publishers or subscribers. MQTT.MQTTPublisher might already return an error.
status: closed --> open
Milestone: SFP: Device --> 2.0.0.0: Device
--- old+++ new@@ -1,21 +1,9 @@-EoN Node will initially be developed to only send its own Metrics. Later, in this ticket, we will also support devices, which are children of EoN Nodes.-
Advantages of Devices:
-* Can tell when they come online/go offline-* Can help logically sort data+* Can tell when a device online/go offline,+* Helps logically sort data on client and server side,
-Workaround: until this is implemented, all Metrics that would have been put in a device, can be published instead as EoN Node Metrics--Ideas for implementation:
FB_Device
- - based on FB_EoN- - every FB_Device has its own Publisher- - every FB_Device has its own Subscriber- - every FB_Device has its own AllMetricsList- - shared connection with the EoN. i.e. there is only one connection--an ARRAY [*] of FB_Device will be passed by the user to FB_EoN--"not enough subscribers" error too, for MQTT.MQTTParam.g_udiMaxPublishersAndSubscribers-This is not yet needed, as we are generally under the default value of 20 publishers or subscribers. MQTT.MQTTPublisher might already return an error.+ - Based on List Element,+ - shares the connection with the EoN i.e. there is only one connection,+ - The user ties an arbitrary number of Devices to the EoN.
--- old+++ new@@ -1,9 +1,13 @@-Advantages of Devices: -* Can tell when a device online/go offline,-* Helps logically sort data on client and server side,-* Application nodes can look only at devices they are interested in (for example a HMI node that only wants data for the page it is on)+Advantages of Devices++ - Can tell when a device online/go offline,+ - Helps logically sort data on client and server side,+ - Application nodes can look only at devices they are interested in (for example a HMI node that only wants data for the page it is on)
FB_Device
- - The user ties an arbitrary number of Devices to the EoN.+ - The user ties an arbitrary number of Devices to the EoN,+ - Implements the same dynamic arrays of Sparkplug values as EoN,+ - The EoN can iterate through the connected FB_Devices via a list and sends all relevant Data to Primary SCADA
--- old+++ new@@ -10,4 +10,12 @@
- - The EoN can iterate through the connected FB_Devices via a list and sends all relevant Data to Primary SCADA + - The EoN can iterate through the connected FB_Devices via a list and sends all relevant Data to Primary SCADA+++v1.1.0.0 implements the basis for a List of Devices+From this version onwards we can expand The EoN and the Device to accommodate the appropriate code++Projected versioning;+V1.3.0.0: EoN sends all Device Data too+V1.5.0.0: EoN can receive commands and distinguishes them for itself or a child Device
--- old+++ new@@ -12,10 +12,6 @@
--v1.1.0.0 implements the basis for a List of Devices-From this version onwards we can expand The EoN and the Device to accommodate the appropriate code--Projected versioning;-V1.3.0.0: EoN sends all Device Data too-V1.5.0.0: EoN can receive commands and distinguishes them for itself or a child Device+[x] v1.1.x.x solution implements the basis for a List of Devices+[ ] V1.4.x.x solution sends all Device Data too+[ ] V1.7.x.x solution can receive, digest and follow up DCMD's
--- old+++ new@@ -12,6 +12,6 @@ - Implements the same dynamic arrays of Sparkplug values as EoN,
-[x] v1.1.x.x solution implements the basis for a List of Devices-[ ] V1.4.x.x solution sends all Device Data too-[ ] V1.7.x.x solution can receive, digest and follow up DCMD's +* [x] v1.1.x.x solution implements the basis for a List of Devices+* [ ] V1.4.x.x solution sends all Device Data too+* [ ] V1.7.x.x solution can receive, digest and follow up DCMD's
--- old+++ new@@ -12,6 +12,8 @@
--- old+++ new@@ -10,10 +10,9 @@ - shares the connection with the EoN i.e. there is only one connection,
- - The EoN can iterate through the connected FB_Devices via a list and sends all relevant Data to Primary SCADA+ - The EoN can iterate through the connected FB_Devices via a list and sends all relevant--+Data to Primary SCADA* [x] v1.1.x.x solution implements the basis for a List of Devices
--- old+++ new@@ -13,6 +13,7 @@ - The EoN can iterate through the connected FB_Devices via a list and sends all relevant
-* [ ] V1.4.x.x solution sends all Device Data too+* [x] V1.3.x.x solution allows for multple devices and DDATA* [ ] V1.7.x.x solution can receive, digest and follow up DCMD's
--- old+++ new@@ -15,5 +15,5 @@
-* [x] V1.3.x.x solution allows for multple devices and DDATA+* [x] V1.3.x.x solution allows for multiple devices and DDATA
status: accepted --> pending
--- old+++ new@@ -16,4 +16,4 @@
-* [ ] V1.7.x.x solution can receive, digest and follow up DCMD's +* [x] V1.4.x.x solution can receive, digest and follow up DCMD's // Standard DCMD's digestion has been implemented
Diff:
Diff:
Diff:
Diff:
Diff:
Diff:
Diff:
Diff:
v1.1.x.x TODO
EoN
Rebirth doesn't work. It gets the rebirth NCMD but ignores it.
After some NCMDs(20)it picks it up.
Device
Does not DBIRTH, just starts sending DDATA.
Diff:
Diff:
Diff:
