Initial implementation will be suitable for an AWS IoT Core MQTT, but can be expanded as needed.
TODO: How to get trusted certificates in there? i.e. AWS's public certificates
TODO: Update with pictures of UI
TODO: renew certificate when it expires
On three seperate devices:
* EoN Node
* SCADA / IIoT Host
* Authenticator
check if he has a private key yet. If not, generate a private key and CSR.
check if he has a Certificate yet. If not check if he has a CSR yet. If notgenerate a CSR.
The CSR is not a secret, so publish the text of the CSR on a visualization.
have a text entry field on the visu to receive the signed certificate and install it for use.
CODESYS Lib: CmpX509Cert
CODESYS Example project: CryptoCertDemo
Authenticator's only job is to take Certificate Signing Requests, and send them to AWS to register the device.
Interface:
3 text fields, same for all nodes / hosts:
* copy and paste your super secret amazon API key (from AWS)
* copy and paste the AWS arn (copy it from AWS)
* copy and paste the sparkplugB group_id
then for each MQTT Client:
* copy and paste the text of the csr
* copy and paste the EoN Node name or SCADA / IIoT Host name (user's responsibility to assign unique names. AWS will probably give an error, if you assign a duplicate name)
* select wether EoN Node or SCADA / IIoT Host (OR BOTH!)
* Hit "register"
* This info is then sent via this API, which returns the signed public certificate:
https://docs.aws.amazon.com/iot/latest/apireference/API_RegisterThing.html
https://docs.aws.amazon.com/iot/latest/developerguide/provision-template.html#bulk-template-example
* will display the response from AWS (eg. SUCCESS)
Note: it would be trivial to add application node, (same as SCADA / IIoT, but accept a list of allowed Nodes to read from, allowed nodes to write from, and whether it is allowed to publish its state)
Note: I am not a security expert, so this implementation will need to be risk assessed for suitability in what the user wants to run it.
https://store.codesys.com/crypto-example.html
Also, be sure to check the Codesys Security Screen package, as it can also generate certificates for various purposes.
I don't know if they can be utilised for MQTT certificates though.
The security screen cannot, but the security agent can (they sound so similar!) https://store.codesys.com/codesys-security-agent.html
For me though, logging in to 50 controllers and remembering what all the buttons are for your particular server is too slow.
Diff:
Diff:
I think we have two options to provide user certificates;
1) Let the user embed a certificate into the compiled application itself (so enclosed as WSTRING variable "blob" )
2) Let the application search for the correct files on a drive (a path with a filename).
Both scenario's have their specific pro's and con's so maybe we should offer the user BOTH options as a choice?
PS I'd recommend only to read these certificates and not provide tooling to generate them. There are hundreds of alternatives out there to generate private key/public key pairs and CA root / private / public certificates.
Once generated via the preffered method of choice the user can either embed the file into the project as variables (a WSTRING should do via C/P) or we pick it up via a file open/read.
Implemented, but "Authenticator" functionality will be moved to new project.
