So looking at the attached .txt, you can see that each metric can have:
So in theory you could receive a payload: Payload.metric[0].properties.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].propertyset_value.values[0].string_value 'ad finitum'
Same for: Payload.metrics[0].template_value.metrics[0].template_value.metrics[0].template_value.metrics[0].template_value.metrics[0].template_value.metrics[0].template_value.metrics[0].template_value.metrics[0].template_value.metrics[0].template_value.metrics[0].template_value.metrics[0].template_value.metrics[0].template_value.metrics[0].template_value.metrics[0].template_value.metrics[0].template_value.metrics[0].template_value.metrics[0].template_value.metrics[0].template_value.metrics[0]
Take for example "Payload.metrics[].dataset_value.rows[].elements[].string_value"
This is fine for encoding, because you can build only the array elements you need.
If we limit the decoder statically (even with values set in the user application), to allow any of 64 incoming metrics to have a dataset with 64 rows and 10 columns, which any could be allowed to be string(80)s, would require 81 x 10 x 64 x 64 = 3MB just for that address.  repeat for the others, allow for a few more rows of data, and you've quickly filled your memory.
So this ticket is to discuss the structure of the memory management.  Some options I can currently think of:
1. Convert to JSON or XML using one of those libraries, and then use the same JSON or XML library to access the data
2. Each Payload has a metric pool array, properties pool array, dataset pool array, template pool array.  Rather than a metric having his own arrays, he just has index values to the pools.
3. Use one of the FB_Factories to allow dynamic creation and distruction of FB instances.
I will put this ticket in the 999.0 backlog, and for milestone 1.0 FB_Payload will only support those fields listed in the ticket [#11]
Ticket [#11]: Large 'static' address space for decoding Payload Blobs
Take for example "Payload.metrics[].datasetvalue.rows[].elements[].stringvalue"
I'd opt for static limit of 32 devices per address.
We could opt for a user dependent max setting (library parameter) and default it to 32.
Reason is memory usage. Plus 32 devices behind a single Node is quite a few devices if you ask me...
If needed, the setting can be changed by the user. Then their mileage may vary.
Ticket 999 options
Option 3 seems the nicest too me. I am open to this option but I am hesitant towards long term usage in an industrial environment stability wise. Using it in a lab environment should be no issue at all.
Related
Tickets:
#11Payload has LinkedList of PayloadMetric
PayloadMetric has propertyset, which is a linked list of keys + a linked list of values. Maybe key+propertysetvalue pair?
propertysetvalue has propertyset, which is a linked list of keys + a linked list of values. Maybe key+propertysetvalue pair?
propertysetvalue has linked list of propertyset
PayloadMetric has dataset, which is a linked list of cloumns + linked list of types + linked list of Rows.
Rows are a linked list of elements.
Metrics has a template, which has a linked list of Metrics + linked list of parameters
FB_Payload has pool of metrics + pool of keys+pool of propertysetvalues + pool of propertysets + pool of columns + pool of datasettypes + pool of rows + pool of elements + pool of parameters
Extends LinkedListElementBase
METHOD FB_reinit : BOOL VAR_INPUT END_VAR
UpdateElement(itfElement := THIS^);
A very good solution to implement a linked list!
