I suspect this is caused as a side-effect of previously not having silo'ed the testcode correct. E.g a having a single FB and several different testmethods that access the single FB. This way of programming should be avoided in the future.
If I encounter this specific issue, I'll post the code which causes the behaviour.
@aliazzz do you have a sample code where this can show this?
We should use this on the List FB, so that you cannot assign a list to a list.
eg: List1 := List2;
{attribute 'no_assign'}
When you do assign a list to a list, both lists think they own the same objects, but they don't, and that's all kinds of mess.
Smart addition! => Saves a lot of headaches 💪
Done, List is now decorated with;
