#56 Edge_node_id and group_id elements may not contain /, #, + characters
1.0.0.0: EoN
closed
aliazzz
2020-09-30
2020-09-13
aliazzz
No
Update code to check/replace these illegal characters "/,+,#" from the Edge_Node _Id or Group_id element
The illegal characters will be replaced with an underscore "_"
Discussion
  • aliazzz
    aliazzz - 2020-09-13
    • status: open --> accepted
    • assigned_to: aliazzz
  • aliazzz
    • summary: Edge_node_id may not contain /, #, + characters --> Edge_node_id and group_id elements may not contain /, #, + characters
    • Description has changed:
    Diff:
    --- old
    +++ new
    @@ -1 +1 @@
    -Update code to check/replace these illegal characters (/,+,#) from the Edge_Node _Id name
    +Update code to check/replace these illegal characters (/,+,#) from the Edge_Node _Id or Group_id element
  • i-campbell
    i-campbell - 2020-09-15
    • Milestone: MVP EoN --> 1.0.0.0: EoN
  • aliazzz
    aliazzz - 2020-09-24
    Diff:
    --- old
    +++ new
    @@ -1 +1,3 @@
    -Update code to check/replace these illegal characters (/,+,#) from the Edge_Node _Id or Group_id element
    +Update code to check/replace these illegal characters "/,+,#" from the Edge_Node _Id or Group_id element
    +The illegal characters will be replaced with an underscore "_"
  • aliazzz
    • status: accepted --> pending
  • aliazzz
    Implemented in v0.0.0.25 in aliazzz Personal Branch
  • aliazzz
    aliazzz - 2020-09-30
    Pushed into trunk v0.0.0.26
  • aliazzz
    • status: pending --> closed
Log in to post a comment.
