codesys.com Ingo Falk
Hardware
Usage
CLK --> GPIO 0
DT --> GPIO 1
SW --> GPIO 3
+ --> 5.0 VDC Power
GND --> 0 V (Ground)
At this point you could install another KY040 if you want to play for example "retro-games" (How to install: https://forge.codesys.com/lib/retro-games/wiki/Home/)
On the picture below you can see an example of the retro-games project. By inserting a "Box" out of your ToolBox it is very easy to program it.
