codesys.com Ingo Falk
How to bind a Rotary Encoder
Hardware
Usage
Setup:
CLK --> GPIO 0
DT --> GPIO 1
SW --> GPIO 3
+ --> 5.0 VDC Power
GND --> 0 V (Ground)
At this point you could install another KY040 if you want to play for example "retro-games".
