A very common way to integrate your own I/O drivers is to use an FB interface inside of a library. A much better way, and much more convenient from the usability is the integration in form of a real I/O driver. This abroach should always been choosen when you decide to share your driver with others.
To implement an I/O driver in CODESYS you need mainly two things:
In the following you will find some general rules to follow while implementing your driver. Beside this guide, you should check out the different templates for different kinds of drivers to start from. Because in detail the implementation will be diffferent if you implement an SPI driver or you read a value from a sensor using a REST API.
But independent of the kind of driver, which you plan to implement. If you are not routined in writing such software, it is a good idea to prove the access of the hardware directly in an application.
Every device, which you can add to your CODESYS project, is described in an XML format inside of a Device Description.
For finetuning and to get a deeper understanding of the format, please check out the schema file. In the following we will just explain the basics to enable you to write your first description.
That the device can be uniquely identified in the device repository on every computer in the world, we need to maintain a few IDs. Please register the ID, which you will be using in the [DeviceDatabase].
Note: The combination of all IDs, described above has to be globally unique. Official versions of a driver with the same IDs, but different content shall never exist.
A device or module, which you can add to the device tree in CODESYS contains at least one connector. This connector is used to attach the module to a parent device.
<Connector moduleType="8023" interface="Common.PCI" role="child" explicit="false" connectorId="1" hostpath="-1">
<InterfaceName name="local:PCI">PCI-Bus</InterfaceName>
<Slot count="1" allowEmpty="false"></Slot>
</Connector>
Interfaces are symbolic names to match compatible connectors, so to find compatible devices or modules. We have some different concepts to configure our device tree in CODESYS.
<Connector moduleType="8023" interface="OpenSource:Internal" role="parent" explicit="false" connectorId="2" hostpath="1">
<InterfaceName name="local:internal">Internal</InterfaceName>
<Var max="4"></Var>
<Connector moduleType="8023" interface="OpenSource:FixConnectorInterface" role="parent" explicit="false" connectorId="2" hostpath="1">
<Fixed>
<!-- This is an example of a fixed module specified in the same file -->
<Module>
<LocalModuleId>8023</LocalModuleId>
</Module>
<!-- This is an example of a fixed module specified by DeviceIdentification. The defininition of this module is in another *.devdesc.xml -->
<Module>
<DeviceIdentification deviceType="40107" deviceId="0001 bcde" version="3.5.9.0"/>
</Module>
</Fixed>
This was a huge preamble for an easy topic. But it was important that you get an idea of how the result will look like.
Interfaces are easy. You define one interface per child connector and one for every parent connector. There are no fix restrictions for the interface names. But it is an unofficial rule, that they should be prefixed with a short or full name of the vendor.
<Connector ConnectorId="2" HostPath="-1" interface="MyCompany.A" moduleType="40101"
role="parent">
<Slot allowEmpty="false" count="16"/>
</Connector>
<Connector ConnectorId="3" HostPath="-1" interface="MyCompany.B" moduleType="40102"
role="parent">
</Connector>
<Modules>
<Module>
<ModuleId>1701</ModuleId>
<DeviceInfo>
<Name name="localStrings:Name1704">Digital Input</Name>
<Description name="localStrings:Desc1704"/>
<Vendor name="localStrings:3S">3S-Smart Software Solutions</Vendor>
<OrderNumber/>
</DeviceInfo>
<Connector ConnectorId="2" HostPath="-1" interface="MyCompany.A" moduleType="41101"
role="child">
<Slot allowEmpty="false" count="1"/>
<HostParameterSet>
<Parameter ParameterId="1000" type="std:BIT">
<Attributes channel="input" download="true" functional="false" offlineaccess="readwrite"
onlineaccess="readwrite"/>
<Default>0</Default>
<Name name="local:in1">in1</Name>
</Parameter>
</HostParameterSet>
</Connector>
</Module>
<Module>
<ModuleId>1702</ModuleId>
<DeviceInfo>
<Name name="localStrings:Name1705">Digital Output</Name>
<Description name="localStrings:Desc1705"/>
<OrderNumber/>
</DeviceInfo>
<Connector ConnectorId="3" HostPath="-1" interface="MyCompany.A" moduleType="41102"
role="child">
<HostParameterSet>
<Attributes channel="output" download="true" functional="false" offlineaccess="readwrite"
</Parameter>
</HostParameterSet>
</Connector>
</Module>
<Module>
<ModuleId>1703</ModuleId>
<DeviceInfo>
<OrderNumber/>
</DeviceInfo>
<Connector ConnectorId="4" HostPath="-1" interface="MyCompany.B" moduleType="41103"
role="child">
<HostParameterSet>
</Parameter>
</HostParameterSet>
</Connector>
</Module>
<Module>
<ModuleId>1704</ModuleId>
<DeviceInfo>
<Name name="localStrings:Name1706">PWM Output</Name>
<Description name="localStrings:Desc1706"/>
<OrderNumber/>
</DeviceInfo>
<Connector ConnectorId="5" HostPath="-1" interface="MyCompany.B" moduleType="41104"
role="child">
</Connector>
</Module>
</Modules>
A device can rughly hold two kinds of parameters:
Both can be configured with the same structured datatypes.
They can be located globally on device level, then they are called DeviceParameters. If they are part of the device that the user adds to the tree, then, they are called HostParameters and attached to one of its connectors.
You can use virtually every datatype for a parameter, which can be used in IEC61131. This includes especially arrays and structures.
But you have to be aware that you need to define those datatypes consistently twice (in your driver library and your device description). There is no extra check. If they don't match between your device description and your code, it will just not work, crash, or whatever...
Some examples...
Basic datatypes don't need a declaration. They can be used with the namespace prefix "std". So "std:BOOL" is the equivalent of a BOOL datatype in IEC.
DevDesc:
<Parameter ParameterId="1000" type="std:DWORD">
<Attributes channel="input" download="true" functional="false" offlineaccess="write" onlineaccess="readwrite" />
<Name name="local:DWIN">DWORD Input</Name>
<Description name="local:DWIN.Desc">DWORD Input</Description>
</Parameter>
IEC:
TYPE DUT :
STRUCT
BYTE1 : BYTE;
BYTE2 : BYTE;
BYTE3 : BYTE;
BYTE4 : BYTE;
END_STRUCT
END_TYPE
DevDesc:
<StructType name="local:Channel4Byte">
<Component identifier="Byte0" type="std:BYTE">
<Default />
<VisibleName name="local:Byte0">Byte0</VisibleName>
</Component>
<Component identifier="Byte1" type="std:BYTE">
<Default />
<VisibleName name="local:Byte1">Byte1</VisibleName>
</Component>
<Component identifier="Byte2" type="std:BYTE">
<Default />
<VisibleName name="local:Byte2">Byte2</VisibleName>
</Component>
<Component identifier="Byte3" type="std:BYTE">
<Default />
<VisibleName name="local:Byte3">Byte3</VisibleName>
</Component>
</StructType>
<Parameter ParameterId="1000" type="local:Channel4Byte">
</Parameter>
IEC:
TYPE DUT :
STRUCT
BYTE1 : BYTE;
BYTE2 : BYTE;
BYTE3 : BYTE;
BYTE4 : BYTE;
END_STRUCT
END_TYPE
DevDesc:
<BitfieldType basetype="std:BYTE" name="Bitfield">
<Component identifier="Bit0" type="std:BOOL">
<Default />
<VisibleName name="local:Bitfield.Bit0">Bit0</VisibleName>
</Component>
<Component identifier="Bit1" type="std:BOOL">
<Default />
<VisibleName name="local:Bitfield.Bit1">Bit1</VisibleName>
</Component>
<Component identifier="Bit2" type="std:BOOL">
<Default />
<VisibleName name="local:Bitfield.Bit2">Bit2</VisibleName>
</Component>
<Component identifier="Bit3" type="std:BOOL">
<Default />
<VisibleName name="local:Bitfield.Bit3">Bit3</VisibleName>
</Component>
<Component identifier="Bit4" type="std:BOOL">
<Default />
<VisibleName name="local:Bitfield.Bit4">Bit4</VisibleName>
</Component>
<Component identifier="Bit5" type="std:BOOL">
<Default />
<VisibleName name="local:Bitfield.Bit5">Bit5</VisibleName>
</Component>
<Component identifier="Bit6" type="std:BOOL">
<Default />
<VisibleName name="local:Bitfield.Bit6">Bit6</VisibleName>
</Component>
<Component identifier="Bit7" type="std:BOOL">
<Default />
<VisibleName name="local:Bitfield.Bit7">Bit7</VisibleName>
</Component>
</BitfieldType>
<Component identifier="Byte0" type="local:Bitfield">
<Default />
</Component>
<Component identifier="Byte1" type="local:Bitfield">
<Default />
</Component>
<Component identifier="Byte2" type="local:Bitfield">
<Default />
</Component>
<Component identifier="Byte3" type="local:Bitfield">
<Default />
</Component>
</StructType>
</Parameter>
