#3 Build a SparkplugB scada in CODESYS
wont-fix
2022-11-05
2020-03-26
aliazzz
No
Build an application which can consume/produce Sparkplug-B messages for testing and debug purposes.
This application should demonstrate the usage and power of the sparkplug.
This Ticket should be implemented after the FB_EoN_Node is done.
Discussion
  • i-campbell
    i-campbell - 2020-03-26
    I think this should read "build a sparkplug B scada Out of CODESYS". Thoughts?
  • aliazzz
    aliazzz - 2020-03-26
    Hmmm, also a possibility!
    The FB_EoN_Node essentially acts as producer/consumer so it is possible.
    Our main goal is to debug the MQTT message contents so that the message fits the Sparkplug B protocol.
    This route will take less time I guess
    (We can always execute the original idea in a later stage of the implementation)
  • aliazzz
    aliazzz - 2020-03-27
    • summary: Set up a Sparkplug B Consumer for testing purposes --> Build a SparkplugB scada in CODESYS
    • Description has changed:
    Diff:
    --- old
    +++ new
    @@ -1,6 +1,9 @@
    -Find an **opensource** and **free** SCADA package which can consume/produce Sparkplug-B messages for testing and debug  purpose. Any platform (windows, linux, and/or docker(!) hosted) will suffice.
    +Build an application which can consume/produce Sparkplug-B messages for testing and debug purposes.
    -* Find SCADA candidate,
    -* Install it,
    -* Configure it,
    -* Announce it.
    +This application should demonstrate the usage and power of the sparkplug.
    +This Ticket should be implemented after the FB_EoN_Node is done.
    +The application needs a broker, so a suggestion would be to use an open to public broker in order to easily test the application hassle free. Local brokers or brokers with encryption can be setup in a later stage because they are not mandatory to debug the code.
    +Any and all suggestions are welcome
    • Milestone: 1.0 --> 2.0
  • i-campbell
    i-campbell - 2020-03-28
    • Milestone: 2.0 --> 3.0
  • i-campbell
    Diff:
    --- old
    +++ new
    @@ -3,7 +3,3 @@
    -The application needs a broker, so a suggestion would be to use an open to public broker in order to easily test the application hassle free. Local brokers or brokers with encryption can be setup in a later stage because they are not mandatory to debug the code.
    -Any and all suggestions are welcome
  • i-campbell
    i-campbell - 2020-10-09
    • Milestone: SFP: SCADA --> 2.0.0.0: SCADA
  • i-campbell
    i-campbell - 2020-12-23
    • Milestone: 2.0.0.0: Primary Server Application --> 2.0.0.0: SparkplugB Primary Node
  • i-campbell
    • labels: Consumer, SCADA --> Consumer, SCADA, Duplicate
    • status: open --> wont-fix
    • assigned_to: i-campbell
  • i-campbell
    Duplicates [#59].
    Related
    Tickets: #59
Log in to post a comment.
